Explore our full platform →
AI Image Translator Demo
Translate a Nutrition Facts label from Russian to Simplified Chinese
Looking for a fast and accurate online image translator?
Our AI-powered image translation tool makes it easy to translate text from images while preserving the original design. Whether you need to translate labels, signs, or documents, our tool ensures high-quality results with intuitive editing options.
In this guide, we’ll walk you through translating a nutrition facts label from Russian to Simplified Chinese, demonstrating how to use the tool effectively for seamless AI image translation.
Step 1
Upload the Image and Start Translation
Begin by dragging and dropping your image into the upload area of our AI image translator. Alternatively, you can click the Upload button to select your file manually. Once uploaded, choose the target language—in this case, Simplified Chinese—and click Translate. The AI will quickly recognize and translate the text while keeping the formatting intact.
Step 2
Adjust Font Size for Consistency
After translation, you may notice some text blocks appear in different font sizes. No worries! Simply select the text blocks, adjust the font size in the settings pane, and make everything uniform for a professional look.
Step 3
Bold the Attribute Text for Clarity
Certain text blocks contain structured information, like “Attribute: Value” pairs. To improve readability, make the attribute text bold. For example, if you see ‘按照:国家标准 2077-2023 制作’, select the part before the colon and click Bold to emphasize it.
Step 4
Resize and Reposition Text Blocks
Due to translation length differences, the text blocks may need some realignment. Simply click and drag the text blocks to the correct position, ensuring there’s no awkward spacing. Then, use the Alignment Tool to neatly align the text to the left.
Step 5
Clean Up the Background
Sometimes, OCR may leave small marks or background noise. Our AI Inpainting Tool lets you easily remove these imperfections. Click the Repair Tool, drag over the unwanted marks, and click Repair Masked Area. The AI will clean up the image, leaving a polished final look.
Step 6
Enhance the Title Text
Titles often stand out with a larger font. Select the title text and choose a font that suits the translated language—Simplified Chinese, in this case. Then, increase the font size, bold the text, and center align it for a professional finish.
Step 7
Export the Translated Image
You’re all set! Your AI-translated nutrition label is now flawless and ready to use. Click the Export button at the top right to download your final image.
Want to see more demos?
Try Our AI Image Translator Today
Experience the ease of translating text in images with our cutting-edge AI technology. Start using this Beta feature now and see how it transforms the way you communicate across languages.
Loading
Signing-in 3 seconds...
Signing-up 3 seconds...
