AI Image Translator Demo
Are you looking for an online image translator that can help you quickly and accurately translate text in images? Whether you need to translate a diagram, infographic, or any other visual content, our AI image translation tool is here to make it easy.
In this article, we’ll guide you through the simple process of translating a Google Cloud Platform diagram from English to Spanish, showing you how to use our tool step-by-step. With our AI-powered image translation, you’ll be able to preserve the design, layout, and fonts while ensuring the translated text fits perfectly into your image. Let’s get started!
Start by uploading your image to our online image translator. Simply drag and drop the image into the upload area, or click the “Upload” button to choose a file from your device. Once your image is uploaded, select your desired target language – in this case, Spanish – and hit the Translate button. It’s that simple!
After translation, you may notice that the text blocks appear in varying font sizes. But don’t worry! Our tool allows you to quickly adjust this for consistency. Just click on any text block in your diagram and enter your desired font size in the settings pane on the right-hand side. Now, your text is all in the same size, making your diagram look much cleaner. If you notice any text spilling over the shapes, we’ll fix that in the next step.
Positioning text correctly in your diagram is quick and easy with our AI image translation tool. Simply click on any text block and drag it to where it fits best. If needed, you can resize the block by dragging the resize handle at the bottom right corner. This step ensures everything looks aligned and balanced.
Sometimes, the OCR process can leave behind unwanted artifacts or “dirt” on your image. But don’t worry – our tool comes with an advanced AI inpainting feature to clean up the background. Click on the Repair tool, and simply drag over the unwanted areas. The tool will create a mask around the area, and you can click on “Repair Masked Area” to remove those unwanted marks. Voilà! Your image is now clean and polished.
Titles in diagrams often have larger or more prominent fonts. Let’s make sure the title of your diagram stands out in Spanish as much as it did in English. Select the title text – “Google Cloud Platform” in this case—and choose a font that suits the language. Increase the font size as needed, and you’re all set with a professional-looking, enhanced title!
After following these steps, you now have a beautifully translated diagram in Spanish. Once you’re satisfied with the result, it’s time to export your image. Click on the Export button at the top right, and save your translated image. It’s that easy to convert your content with our AI-powered image translation tool!
Experience the ease of translating text in images with our cutting-edge AI technology. Start using this Beta feature now and see how it transforms the way you communicate across languages.
