AI-Powered Image Text Translation
Add Custom Text
Customize Your Images by Adding Text Anywhere
Sometimes, you may need to add text to an image manually, whether for captions, headings, or extra annotations. The Add Custom Text feature lets you do just that, giving you the flexibility to insert any text you want into the image. Whether you’re enhancing an image with translated text or creating a new visual asset, this feature gives you complete control over the content you add.
Why Adding Custom Text is Essential
While image translation works wonders for translating the text already present in your images, there are times when you’ll need to add your own. Here’s why the Add Custom Text feature is so useful:
The Add Custom Text feature gives you complete control over your image’s messaging, allowing you to easily include text that fits perfectly with your visual content.
When to Use the Add Custom Text Feature
The Add Custom Text feature can be incredibly useful in a variety of situations:
How to Add Custom Text
  • Step 1: Upload Your Image
    Choose the image you want to add custom text to.
  • Step 2: Click to Add Custom Text
    Select the “Add text” option from the toolbar.
  • Step 3: Type Your Text
    A text box will appear on the image, where you can type in your desired text. You can adjust the size, font, and color to match the style of your image.
  • Step 4: Position the Text
    Once you’ve added the text, move it to the desired position on the image. Resize and rotate the text as needed to fit perfectly.
  • Step 5: Review & Export
    After adding and adjusting the custom text, review the final image and export it in your preferred format.
Why Adding Custom Text Improves Your Image Translations
The Add Custom Text feature enhances the value and versatility of your translated images by:
Pro Tips for Adding Custom Text
Related Features
Try Our AI Image Translator Today
Experience the ease of translating text in images with our cutting-edge AI technology. Start using this Beta feature now and see how it transforms the way you communicate across languages.
Loading
Signing-in 3 seconds...
Signing-up 3 seconds...
