AI Image Translator Demo
Looking for an easy way to translate technical diagrams, charts, and illustrations? Our AI-powered image translation tool helps you translate images online with just a few clicks. Whether you’re working with architectural content, business process diagrams, or complex infographics, our tool ensures high-quality translations while preserving the original layout. In this guide, we’ll walk you through the process using an example – translating a TOGAF architectural diagram from English to Simplified Chinese. Let’s get started!
Start by uploading your image to our online image translator. You can either drag and drop the image into the upload area or click the Upload button to choose the file from your device. Once the image is uploaded, select your target language – in this case, Simplified Chinese – and click Translate. Our AI will analyze the image, recognize the text, and generate the translated version while maintaining the original design.
After translation, you may notice that the text blocks appear in different font sizes. No worries! You can standardize the font size easily. Simply select the text blocks in the image and enter your desired font size in the right-hand panel. Now, all text elements will have a consistent look, making the illustration clean and professional.
Using a font designed for the target language enhances readability and aesthetics. For Simplified Chinese, selecting an appropriate font will make the translated image more visually appealing. Click on the translated text blocks and choose a suitable font from the right-hand panel. For this example, we select ‘ZCOOL XiaoWei’, a font optimized for Simplified Chinese.
Sometimes, after OCR (Optical Character Recognition), small artifacts or unwanted marks appear on the background. Our AI Inpainting Tool allows you to remove these effortlessly. Click on the Repair tool and use it like an eraser – press on the unwanted marks and drag over them. A mask will form over the selected area. Once the mask is in place, click Repair Masked Area, and the tool will clean up the image instantly!
Once everything looks perfect, it’s time to save your translated image. Click on the Export button at the top-right corner. Your flawless, professional-looking TOGAF diagram in Simplified Chinese is now ready to use!
Experience the ease of translating text in images with our cutting-edge AI technology. Start using this Beta feature now and see how it transforms the way you communicate across languages.
