Use Case Scenario Example: Apply a Discount Code
Uncategorized8 months ago
This seemingly simple action has numerous conditions: Is the code valid? Has it expired? Is it applicable to the items in the cart? Has it already been used by the customer? Is it combinable with other offers?
Provide the Use Case Description
First, we feed the AI a detailed use case description. For the best results, include preconditions, main flows, and alternative flows. This rich context helps the AI deliver a more accurate and comprehensive analysis. You can also generate a high-quality description using our AI Use Case Description Generator.
Initiate the Analysis
With the description in place, simply click the “Identify Use Case Scenarios & Core Test Cases” button. Our AI engine will then parse the text to understand its logical structure.
Review the AI-Generated Results
In moments, the AI produces a complete analysis. It automatically extracts all relevant Conditions and Actions, presenting them as clear, easy-to-read lists. The most powerful output is the Decision Matrix, which maps every scenario to its specific conditions and outcomes.
Export and Share
Finally, click Export to HTML to save a standalone copy of the analysis. This makes it easy to share with your team, attach to project documentation, or use as a basis for writing formal test cases.
What’s Next?
  • With this detailed analysis, you have a solid foundation for the next phases of your project. You can now:
    ☑️Automate Promotion Rules: Translate scenarios into business logic to automatically apply promotions, reducing manual oversight.
  • ☑️Optimize User Interface: Design a more intuitive UI that provides clear feedback for invalid codes or restrictions.
  • ☑️Enhance Customer Experience: Use these scenarios to proactively offer alternative discounts or communicate reasons for invalid codes.
  • ☑️Improve Fraud Detection: Implement a logging system to track every attempted discount application, helping to identify fraudulent activity.
Loading
Signing-in 3 seconds...
Signing-up 3 seconds...
