Enroll in Course Example | AI MVC System Architecture Generator
Uncategorized11 months ago
The Enroll in Course use case is a central feature in many e-learning platforms. It shows how a student browses the course catalog, reviews details, checks prerequisites, and confirms enrollment. With the Sequence Diagram Refinement Tool, this flow can be expanded into MVC architecture to reveal how the interface, controller, and backend systems work together to support smooth course enrollment.
Step 1 : Use Case Input
In this example, the topic is about enrolling in a course through an online learning platform. The use case covers how a student navigates the catalog, inspects course details, verifies prerequisites, and completes the enrollment process.
You may either:
  • Write the use case description yourself, or
  • Click “Generate with AI” to let the guided generator help you create a complete description step by step.
After preparing the description, you can continue to generate both the Controller Class Diagram and the MVC Sequence Diagram directly.
Step 2 : Generate MVC Architecture
i. Controller Class Diagram
The tool produces a controller class diagram that highlights the flow of student actions during enrollment. This helps visualize how the controller organizes different interactions before connecting them to the view and model layers.
Controller Class:
  • EnrollCourseController
    • +handleNavigateCatalog()
    • +handleViewCourseDetails()
    • +handleClickEnroll()
    • +verifyPrerequisites()
The diagram can be edited in Visual Paradigm Online for customization or exported as SVG for sharing and documentation.
ii. MVC Sequence Diagram
From the use case description, the tool generates an MVC sequence diagram showing how the student interacts with the catalog and course views, how the controller manages prerequisite checking, and how the backend updates the enrollment records.
With this diagram, you can:
  • Export as SVG for reporting or reference
  • Further refine it using the AI Sequence Diagram Refinement Tool
  • Edit in Visual Paradigm Online to adapt the sequence for your specific platform design
Loading
Signing-in 3 seconds...
Signing-up 3 seconds...
