Edit Tables | AI JSON CRUD Table Maker Tutorial
Uncategorized9 months ago
Loading the Table
To get started, you first need to load a table. You can either start from an existing JSON array to load a table with data, or start from a schema to create an empty table with your defined fields.
Loading a table by pasting a JSON array or using a schema definition.
Example JSON
"project_name": "Q4 Financial Audit",
"department": "Finance",
"priority_level": "High",
"is_approved": true,
"budget_estimate": 12000
"project_name": "Product Launch Campaign",
"department": "Marketing",
"is_approved": false,
"budget_estimate": 25000
"project_name": "Server Infrastructure Upgrade",
"department": "IT",
"priority_level": "Medium",
"budget_estimate": 18000
"project_name": "Supply Chain Optimization",
"department": "Operations",
"budget_estimate": 30000
"project_name": "Employee Training Program",
"department": "HR",
"priority_level": "Low",
"budget_estimate": 8000
Example Schema
project_name: string, department: [Finance|Marketing|IT|Operations|HR], priority_level: [Low|Medium|High]", is_approved: boolean, budget_estimate: number
Key Table Editing Features
01 | Add Record
Insert a new, empty row into your table to input new data.
02 | Delete Record
Remove a selected row from your table.
03 | Edit Record
Open a dedicated editor pane where you can modify the row’s content.
04 | Generate with AI
Use AI to generate new data based on your table’s structure.
05 | Add Record
Sort your data by clicking on a column header.
Data table interface highlighting the Add Record button, edit icons, and delete options.
The Smart Record Editor
String / Number
For these data types, a simple text input box appears, allowing you to directly enter text or numbers.
Text input boxes for string and number data types in the AI JSON CRUD table maker interface.
Selection [A|B|C]
If your schema defines a list of options (e.g., priority:[low|medium|high]), a dropdown menu will appear, allowing you to select a valid option.
Dropdown menu for selecting department options like Finance, Marketing, and HR.
Boolean
For boolean (`true`/`false`) fields, the editor provides a simple checkbox. In the table itself, this will be represented by a checkmark (✅) or a cross (❌) for easy readability.
Boolean field editor showing True and False options with corresponding checkmark and cross icons.
Exporting Your Final Data
Once you are finished editing, you can save your table in either a JSON or CSV file.
Export options for JSON and CSV files in the AI JSON CRUD table maker interface.
Loading
Signing-in 3 seconds...
Signing-up 3 seconds...
