AI JSON CRUD Table Maker Tutorials | Learn Step-by-Step
Uncategorized1 year ago
Loading JSON data to generate a table with CSV export options.
Your Workflow, Simplified.
Welcome to a streamlined approach to data management! This guide will walk you through each powerful feature of the AI JSON CRUD Table Maker, demonstrating just how easy it is to transform raw JSON or a simple schema into a fully editable, AI-enhanced table. Get ready to effortlessly create, manage, and export your data like never before.
Start with JSON
Begin by either pasting your existing JSON array directly into the editor, then press “Load JSON Data” button. Our tool will instantly transforms it into a fully editable table.
JSON Array Example
"employee_id": "E1023",
"name": "Alice Johnson",
"project": "Website Redesign",
"role": "UI/UX Designer",
"hours_allocated": 120,
"deadline": "2025-09-30",
"certified": "Yes"
"employee_id": "E1045",
"name": "David Lee",
"project": "Mobile App Development",
"role": "Backend Developer",
"hours_allocated": 150,
"deadline": "2025-10-15",
"certified": "No"
"employee_id": "E1038",
"name": "Sophie Martinez",
"project": "CRM Integration",
"role": "Project Manager",
"hours_allocated": 100,
"deadline": "2025-09-20",
"certified": "Yes"
"employee_id": "E1072",
"name": "Michael Chan",
"role": "Frontend Developer",
"hours_allocated": 130,
"certified": "No"
Paste JSON Array dialog displaying employee data and Load JSON Data button.
Start from Schema
Define your table’s structure with a simple, human-readable schema. Our app intelligently recognizes data types and sets up your columns automatically.
Schema Example
employee_id:string, name:string, project:string, role:string, hours_allocated:number, deadline:string, certified:[Yes|No]
Define schema interface showing AI JSON CRUD table field generation with employee_id and role examples
Preview the Generated Result
Based on the uploaded JSON, a table with fully populated data will be displayed. If you start from a schema without any values, an empty table will be generated. You can sort the rows by clicking a field name.
Example of a populated data table versus an empty table generated from JSON schema.
Manually Edit the Rows
  • Add a new row using the Add Record button.
  • Remove a row using the Delete Record button.
  • Click the Edit Record button to modify the details in the table.
Clicking the edit icon opens a modal to modify table row details like employee ID and project name.
Generate with AI
Enter the number of rows, then click the Generate button to populate the table with sample data. All generated rows can also be customized with the Edit Record button.
User interface showing Generate button creating sample data rows for name, role, and certified columns.
Export as JSON / CSV
Once your data is perfect, easily export it in the format you need. Choose to download your table content as a clean JSON file, ready for use in your web applications, APIs, or databases.
Alternatively, export it as a CSV file for seamless integration with spreadsheets, data analysis tools, or other business applications. The flexibility ensures your data is always compatible.
Export table data as JSON and CSV formats using the Actions menu.
Loading
Signing-in 3 seconds...
Signing-up 3 seconds...
