Start from Schema | AI JSON CRUD Table Maker Tutorial
Uncategorized4 months ago
What is schema
In simple terms, a schema is a blueprint or a plan for your data. It defines the structure of your table by specifying the name and type of each field (column). For example, a simple schema for a to-do list might be title:string, description:string, priority:[low|medium|high].
Prepare the Schema in JSON CRUD Table Maker
Manually Enter Schema
Directly type your schema string into the input field.
Select a Provided Template
Choose from a list of pre-built templates for common data structures like Member, Product, or Event.
Generate with AI
Describe the data structure you want, and the AI will generate a schema for you.
Populate Your Data
You can now start adding records manually or use the AI to generate sample data for you. The editing pane will automatically adjust to your schema, providing helpful inputs like dropdowns or date pickers
Export Your Data in Other Formats
When your table is complete, you can save your data in either a JSON or CSV file, just as you can when starting from existing JSON.
Categories
Loading
Signing-in 3 seconds...
Signing-up 3 seconds...
