Export Data as JSON or CSV | AI JSON CRUD Table Maker Tutorial
Tutorials2 days ago
Full Workflow
The AI JSON CRUD Table Maker is a powerful tool designed to simplify your entire data management process, from start to finish.
Import Data
Start by either loading an existing JSON array or defining a schema to build a new table from scratch.
Edit & Generate
Add, edit, or delete rows. You can even use the AI to generate new data to quickly populate your table.
Export
Once your table is finalized, you can export it to your desired format.
🔁 Continue Your Work
The best part is the continuity! If you choose to export your table as JSON, you can easily reload that file into the tool at any time to continue editing your data where you left off. This ensures a seamless and iterative workflow.
Exporting Your Data
When all edits are complete and the table is perfect, you can choose to export your final dataset in two popular formats: JSON or CSV.
JSON
What is it? This format saves your data as a new JSON array, maintaining the same structured, key-value pair format as your original data. It’s the native format for web data.
Common Use Cases:
  • Web APIs: When transmitting data between a server and a web application.
  • NoSQL Databases: Storing structured documents.
  • Further Editing: Reloading into the AI JSON CRUD Table Maker to resume your work.
CSV
What is it? Comma-Separated Values is a simple, plain-text format for storing tabular data. Each record is on a new line, and each field is separated by a comma.
Common Use Cases:
  • Spreadsheet Applications: Opening data in programs like Excel, Google Sheets, or LibreOffice.
  • Data Analysis: Importing into data analysis tools.
  • Database Migration: A common format for moving data between different databases.
Loading
Signing-in 3 seconds...
Signing-up 3 seconds...
