Explore our full platform →
Extract UML Classes from Text Description with AI
Our AI-Powered Textual Analysis tool helps you automatically identify candidate domain classes, attributes, and relationships, which you can then refine and edit with our intuitive visual editor.
How it Works: From Text to Diagram
Describe Your App
Enter a simple name or idea to let the AI understand your app concept.
Generate Problem Description
The AI creates a detailed description of your app’s purpose. You can edit it as needed.
Identify Candidate Classes
The tool scans the description and suggests possible domain classes for your system.
Suggest Class Details
Get suggested attributes and operations for each class.
Analyze Class Relationships
AI finds the links between classes, helping define your app’s structure.
Generate & Edit Diagram
A complete class diagram is generated. Make final tweaks with the editor and export it instantly.
Key Features for Complete Control
Real-time AI Analysis
Instantly generate and refine your problem description and class model with our responsive, on-the-fly AI engine.
Review Disqualified Nouns
Get full transparency by seeing which nouns were not considered classes and the reasoning behind their exclusion.
Full Editability
Retain complete control. Easily edit the generated problem description, classes, attributes, relationships, and the final diagram itself with our intuitive editor.
Intelligent Relationship Suggestions
The AI identifies complex relationships like Composition, Aggregation, and Associations with correct multiplicities.
Streamline Your Software Design Process
  • Save Time: Drastically cut down the time spent on manual analysis and diagram creation.
  • Reduce Errors: Minimize human error by leveraging AI to ensure consistency and accuracy.
  • Improve Collaboration: Easily refine, edit, and share models with stakeholders and team members using our intuitive visual editor.
What is Textual Analysis?
Textual analysis is a software engineering technique for identifying candidate domain classes and their properties by analyzing a natural language problem description. Our tool automates this process using AI.
Is the generated class diagram editable?
Yes, the generated diagram is fully editable within our visual editor. You can easily add, remove, and modify classes, attributes, and relationships to perfectly fit your project’s needs.
Can I export the final class diagram?
Yes, the final class diagram can be exported in various formats, allowing you to seamlessly integrate it into your existing documentation and project workflows.
Generate Class Diagrams from Text
Our Class Diagram Generator uses smart textual analysis to identify classes, attributes, and relationships—helping you visualize system structure quickly and refine designs without manual modeling.
Loading
Signing-in 3 seconds...
Signing-up 3 seconds...
