Visual Paradigm Annotator helps researchers capture, organize, and synthesize findings directly from the browser. Turn static web pages into living documents.
While basic highlighters allow you to mark text, Annotator is built for the rigorous process of knowledge management. We help you move from scattered browser tabs to a centralized research library.
Our system forces active processing, ensuring you don’t just ‘see’ data, but understand it.
Group findings from different sources into unified research collections.
Export your annotations directly into JSON, plain text, CSV, and HTML.
Highlight text on any website or PDF. Your marks stay there, even if you refresh the page or return months later.
Access your annotations from any device, anytime. Your research library follows you from office to home.
Install the extension and start highlighting text on any webpage or document.
Add notes, tags, and cross-references to build a cohesive map of knowledge.
Export your findings into JSON, plain text, CSV, or HTML.
Join thousands of professional researchers, academics, and analysts who use Annotator to bridge the gap between discovery and knowledge.
