What Are Decision Tables? Simplifying Complex Scenarios in System Design
Articles3 months ago
Think of preconditions as the rules you need to follow before you can even start a process. In system design, a precondition is something that must be true or a specific state that the system and its actors must be in before a use case can begin. They set the stage, making sure everything is in place for a successful interaction.
A Simple Analogy: Getting Ready to Cook
Before you start cooking a meal, you need to check if you have all the ingredients. In this analogy, having the ingredients is the precondition. If you don’t have them, you can’t start cooking. Similarly, a system needs to meet certain conditions before a user can perform an action.
Examples from Everyday Life
Preconditions are all around us. Here are a few examples:
Boarding a Bus
Use Case: Board the bus.
Preconditions:
  • The bus has arrived at the stop.
  • You have a valid ticket or pass.
Watching a Movie Online
Use Case: Stream a movie.
Preconditions:
  • You are logged into your streaming account.
  • Your internet connection is active.
Why Preconditions Are So Important
By defining preconditions clearly, you can:
  • Prevent Errors: They ensure a use case never starts from a bad or unexpected state, avoiding a range of potential issues.
  • Improve Clarity: They provide a simple way to communicate the exact starting requirements to both developers and testers.
  • Simplify Testing: Preconditions make it clear exactly what a test needs to set up before running a test case.
A Simple Checklist for Writing Preconditions
When you write a precondition, make sure it is:
  • Specific: Don’t write “The user is ready.” Instead, write “The user is logged in.”
  • Testable: Can a tester confirm the condition is true? “The account has a positive balance” is testable.
  • A “Yes/No” Question: The precondition should be something that is either true or false.
Categories
Loading
Signing-in 3 seconds...
Signing-up 3 seconds...
